Any body know how to get to my flasher it only works when it wants to and I can here it when it does but can find it. Help
Nov 2, 2006 at 9:21 AM
AJHARTLE
MEMBER
The 4 way and the directional are the same connection,you have to pull the dash and replace the 4 way hazard switch in the dash. It sounds harder than it is it only took about 15 minutes to do it. The dealer was closed so I got it from the junk yard (20.00). I dont know what the dealer would charge but I think it was a bargain. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Nov 4, 2006 at 4:33 PM
FID13
MEMBER
1 POST
is your emergency flasher switch. dont waste no time looking for the flasher because the flasher is a small relay in the emergency switch. i have the same problem 2 months ago.
Hazard Lamp/Turn Signal Lamp Flasher Integral to hazard switch, left center of instrument panel.
Nov 29, 2006 at 6:17 AM
DAVIDJGRIFFITH
MEMBER
1 POST
My turn signals and flasher have stopped blinking.
I believe the flasher relay has failed.
Where is the relay center in this car?
Dec 13, 2019 at 9:55 AM
(Merged)
DOCFIXIT
✓Experienced Mechanic
These are inside the hazard switch for both turn signal and hazard flashers.
(Merged)
BERNDOGBN
MEMBER
1 POST
Turning signals and hazard lights work intermittently and owners manual does not address. Believe it is flasher relay but I do not know where to locate........................................................................................................................................................................................................................................................................................
(Merged)
HMAC300
it's an internal part of hazard switch left of steering column. but check your grounds at front and rear first
(Merged)
ANTHONY-WAYNE
MEMBER
2002 Chevrolet Monte Carlo, blinkers go out and only come back on when i push the emergency flasher button. How do i fix it?
(Merged)
KHLOW2008
Check the flasher relay. It should be the one that is faulty.
(Merged)
ANTHONY-WAYNE
MEMBER
Thanks, i will check it
(Merged)
ALANSROOFING
MEMBER
1 POST
Turn signals are possessed, they will work and suddenly with no notice will shut off. Sometimes they work and sometimes they don't, it's real strange. Someone told me it may be the blinker switch behind the emergency flashers, is this possible or something else/ Thank you
(Merged)
BLUELIGHTNIN6
definitely could be a sticking/failing signal relay which is behind flasher switch yes. that is most likely cause but not only possibility, it may also be the turn signal switch itself failling.
(Merged)
MAC_LEE
MEMBER
1 POST
i hit my turn signal it the signal lights up and goes of on both sides and it also does that with my hazards lights as well. i tried to look for a flasher relay at pep boys and a lot of other shops but nobody has them. what is the problem?
(Merged)
DENNYP
the hazzard flasher module is bad. It is located in the hazzard switch.
(Merged)
BROOKE163
MEMBER
its a part of the 4 way hazards switch you have to go to the dealer for that
(Merged)
