2000 Chevy Metro
208,880 MILES • 4 CYL • 2WD • MANUAL
ZEPPELINHATER
its kinda a weird thing that happened, i have 00 chvy metro and the dash lights dont work and the tail lights dont work also but the brake lights work fine and so does eveything else, i thought it was the fuse but each time i replaced the fuse it blew every time i started up the the car i think it has something to do with the wiring and i cant figure out what it is
Mar 24, 2009 at 10:56 AM
DOCFIXIT
  • 18,828 POSTS
What fuse is blowing? It blows even if lights are not turned on?
Mar 25, 2009 at 2:42 AM
ZEPPELINHATER
the 15-watt light fuse under the dash, and no it only blows when i turn on the lights
Mar 26, 2009 at 3:28 PM
DOCFIXIT
  • 18,828 POSTS
Most likely a bulb shorted so pull bulbs till fuse dose not blow. Doubt if dash lights are the culprit.
Mar 27, 2009 at 8:33 AM
