street rod
CHEVROLET MASTER DELUXE
1983INDY
Engine Cooling problem
street rod 350 crate motor gm dual exhaust water droplets out of only one of two tailpipes on start up and I am loosing some water out of cooling system closed system that is not drawing water back into radiator no water in oil ??
Nov 29, 2009 at 5:25 AM
HMAC300
  • 48,601 POSTS
no what you see is normal. It's just a combination of the gases being burnt in the engine. One pipe may be cooler than the other when you start. It's nothing to worry about. In the cooler climates you'll see water coming outof the tail pipes all the time.
Jan 10, 2010 at 7:36 AM
