1995 Chevy Master Deluxe battery or alternator
1995 CHEVROLET MASTER DELUXE
10,950 MILES • V8 • 2WD • AUTOMATIC
PHILLY1936
When I try to measure the alternator at the battery it measures about 12.8 volts but when I remove the wire at the back of the alternator and measure it directly the alternator measures 15 volt. I need to make sure there is continuity between the alternator and the starter which is where the wires meet up. Can you think of anything else?
Thanks in advance
Mar 24, 2010 at 2:17 AM
JDL
  • 16,098 POSTS
Just my opinion, don't take anything loose from the alternator, engine running. I'm not sure of vehicle model? Engine off, everything hooked up, take a reading at alternator bat terminal, take second reading at battery posts, the two readings should be very close to the same. You can, just take two readings at the battery posts. First reading, with everything turned off, second reading, engine running. If the charging system is ok, the second reading should be higher than the first.
Mar 24, 2010 at 2:31 AM
