Malfunction of fuel gage indicator
SJ5435
I recently had the fuel injectors on my 1998 Malibu LS cleaned and when I got the car back the fuel gage indicator on the dash was position below the pin. When I turn on the ignition the indicator rest against the pin and when I turn off the ignition the indicator drops down. Appears like some electrical connection is wired backward. Any help would be appreciated.
Oct 29, 2007 at 10:30 AM
2CARPRO JACK
  • 11,533 POSTS
Gm gauges do that sometimes. You need to remove the cluster and manually move the needle around to where it is supposed to be, then it will work again
Oct 29, 2007 at 10:48 AM
