Chevy Malibu Steering Shaft
RJIYER
Hi
I own a 2004 chevy malibu LS edition. My mechanic tells me that the steering shaft of my car has to be replaced. I have extended warranty on my car, but the insurance company says that the warranty covers only internally lubricated parts contained within the steering box and pump housing. They claim that the steering shaft is not an internally lubricated part. Can someone clarify? I am a layperson and have no idea about this
thanks
Jan 22, 2007 at 10:45 AM
CARUNDELL
  • 602 POSTS
[quote:f1f0ccc573="rjiyer"]Hi
thanks[/quote:f1f0ccc573]
Hey rj,
they are basically saying that all they will cover is the power steering pump and the steering rack. All the other components in the steering system are not covered under the warranty
Chris
Jan 22, 2007 at 10:49 AM
SERVICE WRITER
  • 9,123 POSTS
Internal meaning that there is fluid doing the lubricating. The shaft may be under OEM recall, Check with the dealer. The shaft has some grease, but not lubricated in an enclosed environment.
Jan 22, 2007 at 10:51 AM
BONKO98
i had mine replaced also but it was due to a problem i encountered that was under the original warranty and was overlooked on two prior occasions in for repair. the dealershuip made the shaft repair at no cost. you have allerted me to the terms of extended warranties that require indepth attention. unfortunately this is probably of little help to you but allow me to thank you for your information,
Mar 20, 2007 at 12:50 PM
