where is cabin air filter?
BJW04TRAILBLAZER
the cabin air filter is located where?
Oct 9, 2010 at 10:50 AM
This vehicle does not use a cabin air filter. This is not uncommon. These did not become more common until around 2011 so this vehicle does not have one. If there is a must odor that you are dealing with, more then likely you have some issue in the heater core that was pretty common on these.
I attached the info on the HVAC module that shows there is no filter.
Let us know if there is other info needed. Thanks
Nov 25, 2020 at 11:16 AM
