2007 Chevy Malibu steering
44,000 MILES • 4 CYL • FWD • AUTOMATIC
BARB54
car makes noise underneath when driving like rattling. and steering wheel shakes or kinda wobbles when sitting at stop light or in idle. l\i hope that enough information to help. thank you barbara johnson
Jan 14, 2010 at 6:59 AM
  • 110,248 POSTS
Actually, the steering won't rattle. Take a rubber mallot and tap on the exhaust. Chances are there is a heat shield ratteling. Also, check the catylatic converter to make sure the insides didn't come loose. As far as the steering wheel shaking, are you sure it isn't from the engine running rough at an idle? Does it to it when you are not sitting? If so, is it all of the time or at certain times?
Jan 16, 2010 at 11:59 AM
BARB54
the steering wheel shakes when you are driving and have the steering straight if you move the steering a little tleft or right it wont shake if you are sitting at a stop light with the steering wheel straight the steering wheel starts woobling or shaking
Jan 17, 2010 at 12:47 AM
