2007 Chevy Malibu brake lights
40,000 MILES • 6 CYL • FWD • AUTOMATIC
3636CAP
replaced brake switch. Brake lights are on initially, hit brake pedal go off and stays off. Pedal does not control rear brake lights
Aug 31, 2009 at 3:24 AM
JDL
  • 16,098 POSTS
Did you check the connector at the brake pedal position sensor? Ref voltage-- signal-- ground. Also check the park lamps relay and fuse in the rear fuse box. Your owners manual should give you the location of that fuse box. My info says rear quarter-panel, you may have to access from the trunk?
Aug 31, 2009 at 4:39 AM
