2006 Chevy Malibu Rear Turn Signal Bulb Replacement
63,000 MILES • 4 CYL • FWD • AUTOMATIC
CLARKSON49
How do you remove the inner protecive plate from this car to gain access to the turn signal bulbs?
Nov 3, 2009 at 7:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
to replace the rear turn signal bulb perform the following:
open the rear compartment
remove the screws from the tail lamp
from the inside of the rear compartment, pull back the side trim panel then remove the wing nut from the tail lamp.
pull the tail lamp rearward to disengage the lamp from the quarter panel.
now you have access to replace whichever bulb needs it
Nov 3, 2009 at 8:50 AM
