I see brake fluid leaking for the right front?
38,750 MILES • 6 CYL • FWD • AUTOMATIC
OLDSKOOL
I have my foot on the pedal then when I brake I have to have my foot all the way down on the brake pedal I see brake fluid leaking for the right front.
Oct 10, 2009 at 8:37 PM
I attached the process below on how to replace the lines but you are going to have to bleed the brakes afterwards so here is a guide that will help with this:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Plus here is a guide on a different vehicle but the process is about the same:
https://www.youtube.com/watch?v=1Prs_coIuCg
Below is the process from the manual. Let us know if you need other info. Thanks
Mar 26, 2021 at 11:30 AM
