2006 Chevy Malibu fluid change
55,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAM M
no ability to check dipstick, as no dipstick. using the inspection plug, I drained about 6 quarts of atf- then replaced 6 quarts, but I still cannot check the fluid level. it was the first change. just how does a person check the fluid level???
If I pull the pan, will all 9 quarts come out? or about 6 qts?
signed, lost in sacramento- wm
Feb 11, 2008 at 6:25 AM
BMRFIXIT
  • 19,053 POSTS
[quote:c820675934="william m"]Transmission problem
2006 Chevy Malibu 6 cyl Two Wheel Drive Automatic 55000 miles
signed, lost in sacramento- wm[/quote:c820675934]
The inspection hole is located under the car
so u need to get it up on a lift
its right by the out put shaft (right CV axle )
Feb 11, 2008 at 10:27 AM
