2006 Chevy Malibu Check Engine Light
36,000 MILES • 4 CYL • 2WD • AUTOMATIC
MKINGSMILES
The check engine light came on, and I had the car checked to see why. The computer said, "Voltage signal from fuel level sensor is intermittent." I am wondering what exactly that means and how much it will cost me to fix it, or if I even need to fix it. Thank you.
Oct 14, 2008 at 3:26 AM
DOCFIXIT
  • 18,828 POSTS
Does fuel gague work? Car run good then you could ignore
Oct 14, 2008 at 5:08 AM
MKINGSMILES
Yes, fuel gage works. Thank you for your help.
Oct 14, 2008 at 8:06 AM
