I have a 2005 malibu I sometimes hear a thumping like it is in the wheels or suspension area...could it be the struts being weak.
Jul 21, 2008 at 2:04 AM
RHALL77
✓Experienced Mechanic
is it a deep thumping noise or more of a rattle. is it in the front end area. check your sway bar links. could also be a rack and pinion. is this car a classic or is it a new body style.
Jul 21, 2008 at 2:26 AM
MSHORSEGAL
MEMBER
[quote:7040999480="rhall77"]is it a deep thumping noise or more of a rattle. is it in the front end area. check your sway bar links. could also be a rack and pinion. is this car a classic or is it a new body style.[/quote:7040999480]
it doesn't do it all the time just when I either turn on uneven ground or maybe when I stop an start off an the weight of the car shifts...it's just a small thump..have had the rackin pinion checked by mechanic says it is good...I would donate but I am a single parent trying to get by thank y ou so much.
Jul 21, 2008 at 3:58 AM
RHALL77
is it a new body style or old body style. this will make a big difference
Jul 21, 2008 at 4:43 AM
MSHORSEGAL
MEMBER
[quote:ed1edce084="rhall77"]is it a new body style or old body style. this will make a big difference[/quote:ed1edce084]
it is the new body style I believe it look almost like the new ones
Jul 21, 2008 at 5:16 AM
RHALL77
can you feel it in the steering wheel. it sounds like a rack and pinion to me.
Jul 21, 2008 at 5:34 AM
MSHORSEGAL
MEMBER
[quote:28604ecaed="rhall77"]can you feel it in the steering wheel. it sounds like a rack and pinion to me.[/quote:28604ecaed]
I here it more than I feel it...over rough area it feels like no shocks or weak suspension
Jul 21, 2008 at 5:40 AM
MSHORSEGAL
MEMBER
[quote:f8fd465cf3="mshorsegal"][quote:f8fd465cf3="rhall77"]can you feel it in the steering wheel. it sounds like a rack and pinion to me.[/quote:f8fd465cf3]
I here it more than I feel it...over rough area it feels like no shocks or weak suspension[/quote:f8fd465cf3]
I have had a chevy mechanic check it out at his shop he says the rackin penion is in good shape..says it is tight an secure
Jul 21, 2008 at 5:47 AM
MSHORSEGAL
MEMBER
[quote:4ae5458ec9="mshorsegal"][quote:4ae5458ec9="rhall77"]can you feel it in the steering wheel. it sounds like a rack and pinion to me.[/quote:4ae5458ec9]
I here it more than I feel it...over rough area it feels like no shocks or weak suspension[/quote:4ae5458ec9]
