2005 Chevy Malibu shaking
TIFFANYLUCKETT83
Tires and Wheels problem
2005 Chevy Malibu 98666 miles
While I'm driving my car shakes and when pressing on the brakes and shakes can u help?
Mar 3, 2010 at 3:45 PM
BASSTECH
  • 236 POSTS
if the car is shaking while driving that could mean that you have an out of balance tire, a bad tire, or a bent rim. You might want to have a tire shop look at that.
If the car is shaking while your braking, then it is possible that your brake rotors are warpped, or the you need a brake job.
I'd get the tires looked at first to keep it safe.
Let me know how you make out
Mar 5, 2010 at 6:31 AM
MOSHEDSSDD
I am having same problem with my 04 check your brake fluid if it is above then check the brake pads. I'm thinking my problems is Possibly the fluid pump as it only shudders sometimes in the rear.
Apr 12, 2010 at 7:19 AM
