2005 Chevy Malibu Roaring Sound --
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
LRICE38
While driving from speed 10 - 70 MPH, the car makes a loud roaring sound. I had my tires rotated and getting ready to get them rotated again, so I don't believe that's it -- pretty even wear, it seems like it is more along the lines of RPMs -- not shifting correctly. It really sounds like the engine is continually revving up and doesn't completely shift.
Jun 23, 2008 at 6:24 AM
RHALL77
  • 3,361 POSTS
does it set a check engine light? are you loosing power?
Jun 23, 2008 at 6:44 AM
LRICE38
No check engine light comes on and I am not loosing power
Jun 23, 2008 at 6:52 AM
RHALL77
  • 3,361 POSTS
check and see if your tires are cupped. when was the last time you had a alignment? also check for a worn out wheel bearing.
Jun 23, 2008 at 7:35 AM
LRICE38
Tires were rotated just a little over 4,500 miles ago and will be getting them rotated this week -- alignment was done about 15,000 miles ago -- but didn't think about the wheel bearing --I'll check it too --thank you!
Jun 23, 2008 at 7:49 AM
