2005 Chevy Malibu GAS LEVEL MOVING UP AND DOWN
DDE
Engine Mechanical problem
2005 Chevy Malibu 6 cyl Front Wheel Drive Automatic
MY Gas meter goes up and down on a full tank
my gas reader says low fuel....what can this be
Mar 15, 2009 at 6:57 AM
MIKE H R
  • 3,094 POSTS
disconnect the battery and then check the wiring going to the sending unit in the fuel tank, sometimes a loose wire or a bad ground will do it. if that does not help then the sending unit inside the fuel tank is going bad.
Mar 20, 2009 at 1:43 AM
