2005 Chevy Malibu front signal
52,000 MILES • 6 CYL • 2WD • AUTOMATIC
ERICG
my front right signal light does not work, the rear right one works but blinks very fast, i have changed both the front & rear bulbs. but that didn't work.. is there anything else i can try?
Oct 16, 2009 at 4:56 AM
JDL
  • 16,098 POSTS
Welcome to the site, thanks for the donation. I'd check for voltage and ground at the problem lamp circuit. Purple wire is voltage, black is ground. Let us know what you find. Might be a problem with the wiring circuit from bcm to lamp?
Oct 16, 2009 at 5:28 AM
