2005 Chevy Malibu brake calipers
2005 CHEVROLET MALIBU
55,000 MILES • 6 CYL • FWD • AUTOMATIC
PACE1144PA
Is there a trick to compressing the brake pistons. I have changed a lot of brakes and have never had this much trouble changing my brake pads. This is the first time I had to do this on this car and no matter what I do I cannot move the pistons. What am I doing wrong?
Dec 14, 2007 at 12:52 PM
BMRFIXIT
  • 19,053 POSTS
[quote:9eb39022fb="pace1144pa"]Brakes problem
2005 Chevy Malibu 6 cyl Front Wheel Drive Automatic 55000 miles
Is there a trick to compressing the brake pistons. I have changed a lot of brakes and have never had this much trouble changing my brake pads. This is the first time I had to do this on this car and no matter what I do I cannot move the pistons. What am I doing wrong?[/quote:9eb39022fb]
are you doing the front or rear
Dec 14, 2007 at 1:41 PM
PACE1144PA
[quote:650ab8847e="BMRFIXIT"][quote:650ab8847e="pace1144pa"]Brakes problem
Is there a trick to compressing the brake pistons. I have changed a lot of brakes and have never had this much trouble changing my brake pads. This is the first time I had to do this on this car and no matter what I do I cannot move the pistons. What am I doing wrong?[/quote:650ab8847e]
are you doing the front or rear[/quote:650ab8847e]
I am doing the rear brakes
Dec 14, 2007 at 3:24 PM
BMRFIXIT
  • 19,053 POSTS
[quote:ce0dda197b="pace1144pa"][quote:ce0dda197b="BMRFIXIT"][quote:ce0dda197b="pace1144pa"]Brakes problem
Is there a trick to compressing the brake pistons. I have changed a lot of brakes and have never had this much trouble changing my brake pads. This is the first time I had to do this on this car and no matter what I do I cannot move the pistons. What am I doing wrong?[/quote:ce0dda197b]
are you doing the front or rear[/quote:ce0dda197b]
I am doing the rear brakes[/quote:ce0dda197b]
YOU HAVE TO USE A SPECIAL TOOLS FOR THE REAR
IT TURNS THE PISTON AS ITS PUSHING IT IN
U CAN TRY TO TURN THE CALIPER PISTON WITH A BIT OF FORCE PUSH IT IN
Dec 15, 2007 at 4:53 AM
