2004 Gauges reset when attempting to start
70,000 MILES • 4 CYL • FWD • AUTOMATIC
ATTICUS1983
I'm stumped. My car wouldn't start, and I took it to a parts store to have it tested, and they said that the alternator is bad. I just got done putting a new alternator in, and the car started right up. However, I tried rolling the (electric) window down and the car started to die. I revved the engine and the gauges started going all over the place! After that I tried depressing the brake and the car began to sputter again like it was going to die. I tried the turn signals, flicking the lights and rolling the window back up and each time the engine began to die.
The car has a brand-new battery and alternator, and will jump-start just fine. But once it's started, if I try do do anything it will shut off.
Any thoughts on what could be happening and/or how I can fix it?
Aug 17, 2008 at 8:25 AM
SERVICE WRITER
  • 9,123 POSTS
The only brands that I have had good luck with are rebuilt ones by palladium, USA, and the Napa premium line. My bet is the one you installed is bad off the shelf.
Aug 17, 2008 at 8:32 AM
