2004 Chevy Malibu TURNING SIGNAL
2004 CHEVROLET MALIBU
75,000 MILES • 4 CYL • FWD • AUTOMATIC
KIRKB78
I HAVE REPLACED THESE PASSENGER SIDE PARTS: REAR LIGHT LENS/CIRCUIT BOARD/BULBS AND TURNING SIGNAL-MULTIFUNCTION COLUMN SWITCH/FLASHER-RELAY SWITCH ON DASH SO FAR.
Problem: Left turning signal works perfect but passenger signal blinks faster when foot is on brake.
The passenger side "dashboard signal indicator" also stays on but only when foot is on brake.
All I have left to replace is the brakelight switch or the passenger side socket connector THAT GOES TO THE REAR LENS CIRCUITBOARD.
Can you please help me?
This is starting to cost a small fortune.
Feb 22, 2008 at 10:33 AM
BMRFIXIT
  • 19,053 POSTS
Form the sound of it
I would say its a faulty ground wire check that
Feb 22, 2008 at 11:08 AM
KIRKB78
[quote:c956e2e57e="BMRFIXIT"]Form the sound of it
I would say its a faulty ground wire check that[/quote:c956e2e57e]
Where is the ground for this?
Do you mean the ground that is in the socket to the tail light?
Feb 23, 2008 at 9:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e33da89fa3="kirkb78"][quote:e33da89fa3="BMRFIXIT"]Form the sound of it
I would say its a faulty ground wire check that[/quote:e33da89fa3]
Do you mean the ground that is in the socket to the tail light?[/quote:e33da89fa3]
yes
try to run a temp ground and check it that way
good luck
Feb 23, 2008 at 9:58 AM
