2004 Chevy Malibu Turn signals
2004 CHEVROLET MALIBU
26,000 MILES • 4 CYL • 2WD • AUTOMATIC
CATHY ACKERMANN
At times the direction signals will not operate. I checked the owners manual and they do not speak of a signal flasher. I checked the 10 amp fuse in the panel at the left side of the dash, and it was good. I remember in my older cars that a turn signal flashes was to be found on the fuse panel. Do they still use one of these, and where is it? Thank you.
Jun 5, 2009 at 7:27 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
The flasher relay is built in the hazard switch. If you have turn signal or hazard issues, you will need to replace the hazard switch as a whole unit to replace the flasher.
Jun 5, 2009 at 9:15 PM
