2004 Chevy Malibu side view mirror right hand side
87,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGVIC64
how to replace
Jul 1, 2010 at 6:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the front door trim panel. Remove the trim cover. Disconnect the electrical connectors. Remove the nuts from the mirror. Remove the mirror from the front door.
https://images.2carpros.com/forum/automotive_pictures/261618_0996b43f80203072_1.jpg
To install: Position the mirror to the front door. Install the nuts to the mirror, starting at the lower left nut. Tighten the mirror mounting nuts to 89 inch. lbs.(10 Nm). Connect the electrical connectors. Install the trim cover. Install the front door trim panel.
Jul 1, 2010 at 6:40 AM
