2004 Chevy Malibu Rollover
WILDFIRE84
  • 2004 CHEVROLET MALIBU
  • 6 CYL
  • 55,000 MILES
My car recently slid in the ditch and rolled on it's top. It appears to only have body damage, and I lost quite a bit of oil. What else should I look for before/after I start it up?
Saturday, January 3rd, 2009 AT 11:08 AM
LSAUTO
  • 61 POSTS
Need too check the oil for water and pull the plugs too check for oil in cyl I would not start this car untill all fluids have been checked or refilled, also need too check for pinched hoses ot bent lines, if find oil in the engine cyl use a sucktion gun too remove oil or water and install a new set of plugs befor starting, if every thing cks out ok after start up check exgust for smoke ( blue is oil ) ( white is water )
( black is fuel ) if u hear any rattles or knocking shut engine down and find the problem befor restarting u will probly hear some ticking from the lifters @ first start up but should go away after a few mins of running hope this helps and good luck lsauto
Wednesday, January 14th, 2009 AT 2:10 AM
Related General Content
