2004 Chevy Malibu Removing caliper mount bracket
105,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGGNUTTY
You guys make it look soooo easy! But I'll be darned if I can't break loose the 13mm bolts holding the bracket onto the axle. Everything was smooth sailing up until that point, but the rotors are stuck if I can't get the brackets off...all the bolts are on there (each side) unbelievably tight...
Oct 11, 2009 at 6:50 PM
F4I_GUY
  • 3,302 POSTS
Get a long breaker bar with a 13mm socket on it and use some muscle. It'll eventually break loose.
Or you could purchase a good quality penetrating fluid and let it sit for half an hour or so.
Mar 29, 2021 at 7:22 AM
BIGGNUTTY
Thanks for the reply! Ended up just having to replace the pads, but for future reference...
