2004 Chevy Malibu Brake fluid or pads
2004 CHEVROLET MALIBU
MOSHEDSSDD
Brakes problem
2004 Chevy Malibu 4 cyl Front Wheel Drive Automatic 73k miles
Cars shudders at low speed when brakes are applied shudders little when accelerating after. Randomly stops shuddering when brakes applied easier to brake. Is it possible fluid pump needs replaced? Or is it possible the brake pads need to be replaced? Also only shudders in back.
Apr 12, 2010 at 7:03 AM
FACTORYJACK
  • 4,159 POSTS
If frequency of this vibration increases when braking from higher speeds, it is possible that one or more brake rotors have excessive lateral runout. This brake pulsation may vary in severity, depending on temperature. It is hard to say what the condition of the pads are, at 73k. I would recommend a full brake inspection.
Apr 12, 2010 at 3:05 PM
