2004 Chevy Malibu Ball Joints
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
RMD735
My 04 Malibu Maxx needs replacement ball joints. I have discovered that there are just the ball joints and also the ball joint with control arm . The cost for ball joints are around $55 each and the joint with control arm is around $100 each. From what I can tell, places charge 3 to 4 hours of labor either one I choose. Is is easier to replace one over another?
The place I took it said the control arms were okay. When I called GM dealer, they said the only choice I had was the ball joint with control arm assembly.
Thanks in advance
rmd735
Nov 5, 2008 at 2:52 AM
MASTERTECHTIM
  • 4,750 POSTS
my suggestion would be install control arms because if the bushiongs are not bad now they will be soon, i actually replace the control arms for bushing problems mostly so in my opinion for the extra 45 bucks id replace the whole control arm.
Nov 5, 2008 at 3:21 AM
