2003 Chevy Malibu Won't Start
91,000 MILES • 6 CYL • FWD • AUTOMATIC
MEQ1957
The car won't start. It turns over like it wants to but it won't. I have replaced the fuel pressure regulator and the ignition module. It is getting gas to the fuel pressure regulator but not to the carb. are the injectors the problem and how do I know for sure? Thanks
Apr 11, 2008 at 10:17 AM
BLACKOP555
  • 10,386 POSTS
you modle is carbuerated? Throttle body injected, Or electronic fuel injected.
which one is it.
are you sure its carbed?
Apr 11, 2008 at 12:28 PM
MEQ1957
No I am not sure I only know that I took the hose off between the fuel pressure regulator and where the fuel goes into which looks like a small carberator. The engine is 3.1 and is elec. fuel inject. When I pour gas straight into the carb. looking piece the car will sart but hooked back up it won't. How do I check the injectors to see if they are all bad? Do I have to replace all 6 or can I see if they are bad individually? Thanks
Apr 11, 2008 at 4:13 PM
BLACKOP555
  • 10,386 POSTS
you can see which ones bad individually, measure the resistance of each of them, they should be simmilar. if one is totataly off replace it.
next is to check for power, hook upa noid light to the injector connectors and crank the engine, if it cranks its getting pulse and the injectors should be firing.
Apr 12, 2008 at 1:01 AM
