2003 Chevy Malibu starting problems
98,000 MILES • 6 CYL • FWD • AUTOMATIC
JOE GARCIA
my car sometimes does not start but it does crank.this has been a problem for 8 months. i have been stranded 6 times. every time i get it pulled to my house, it starts. i have replaced the fuel pump,and fuel pressure regulator but problem still persist.
Feb 5, 2008 at 12:41 PM
2CARPRO JACK
  • 11,533 POSTS
Are you sure it is fuel pressure that is misisng when it wont start? Need to be sure has spark. Does the security light blink when it wont start?
Feb 7, 2008 at 7:17 AM
JOE GARCIA
i did check the plugs and they do have spark.when the car turns on, it runs real good.this problem only happens about once a month.i have read about the similar problems other have had with these malibus.i drive it. it runs fine, and if i go to the store for example,and get back in to start the car, the motor turns but will not start.i do remember the theft system light blinking for a while,on one occasion i was driving the car. do the keys on these cars have chips in them, i can not tell by looking at the key.
Feb 7, 2008 at 7:51 AM
2CARPRO JACK
  • 11,533 POSTS
You wont be able to by looking at it. Next time it wont start, turn key on for about 10 minutes or until the security light goes off then turn key off and try starting it, this will reset the anti-theft
Feb 7, 2008 at 9:59 AM
JOE GARCIA
just today sunday my car acted up again, i did as you told me about the ten minute key on acc so the computer could relearn the key and it worked,thanks a million. you saved me time from tearing into my relays to the gas pump, which is what i thought was the problem. Next question is can i bypass the security system by rewiring the key switch, i have knowled in the electrical parts in cars.
Feb 10, 2008 at 1:21 PM
2CARPRO JACK
  • 11,533 POSTS
not sure to be honest, I have never tried. If you go here
http://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
you will find a full wiring diagram so you can judge for yourself if it is something you want to try
Feb 10, 2008 at 11:09 PM
