2003 Chevy Malibu RADIATOR AND TRANSMISSION COOLER
2003 CHEVROLET MALIBU
75,000 MILES • 6 CYL • FWD • AUTOMATIC
BLIND1I
IS THE TRANS COOLER LOCATED IN THE RADIATOR? IS IT POSSIBLE FOR TRANS FLUID TO GET IN COOLANT SYSTEM WITH ONLY 75K ON THE CAR? CAN I CHECK IT MYSELF AND OR FLUSH IT MYSELF?
Feb 18, 2010 at 11:10 AM
BASSTECH
  • 236 POSTS
Yes the trans cooler is located in part of the radiator, and yes it's possible for the trans fluid to mix with coolant or vise a verse a. What gives you the idea that they are mixing? Is the coolant or trans fluid low? I wouldn't flush the system until the leak is repaired, because you'll just have to do it again later
Feb 19, 2010 at 3:05 PM
