2003 Chevy Malibu No Injector Pulse
44,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBB04
This car will not run due to no injector pulse. Where does the pulse come from?
Apr 2, 2008 at 2:14 AM
BLACKOP555
  • 10,386 POSTS
the injectors are supplied with voltage when the key is on continuously.
when the vehicle is cranked, the pluse comes when the ECM grounds out the injector causing a circuit and a pluse.
THe information to the ECM comes from the Crank and Cam position sensors for the initial pluse. the width of the pluse, or open time of the injectors are influenced by the O2 sensors, MAF sensor, IAT sensor, ECT sensors, and TPS sensor.
how did you test for injector pulse?
Apr 2, 2008 at 1:27 PM
DBB04
Thanks, But We figured it out. It was the Theft System that caused the problem. Put new ignition switch and cylinder. It fixed the problem
Apr 3, 2008 at 4:03 AM
