2003 Chevy Malibu my driver side window
LUV4KAYCOO
Other Category problem
2003 Chevy Malibu V6 Two Wheel Drive Automatic 79000 miles
The front side of the window wont roll up and i was wondering is it the motor and if so will it be exspensive
Dec 8, 2007 at 11:04 AM
BMRFIXIT
  • 19,053 POSTS
[quote:8cd6a79036="luv4kaycoo"]Other Category problem
The front side of the window wont roll up and i was wondering is it the motor and if so will it be exspensive[/quote:8cd6a79036]
If only one window isn’t working you can say for sure its not a fuse
That will leave switch ----motor/regulator --------wiring
Which one in your case
It may not be the motor if it roll down but wont go up
Do you hear the motor try to work when switch pushed
You have the do a bit of investigating
You need a volt meter or a simple test light
Let me know
Dec 8, 2007 at 2:12 PM
