2003 Chevy Malibu interchange wheels
2003 CHEVROLET MALIBU
85,000 MILES • 6 CYL • FWD • AUTOMATIC
KUNTAO
currently I have 215/60r/15 tires on the vehicle, would like to change wheels to 16". through research I found numerous other gm vehicles with same bolt/lug pattern & offset.Question being, will I have the clearence front & rear? Lumina,Grand Prix,Aurora,Delta-Regency Royal-88,98 are the vehicles I found as mentioned on another web site.
Feb 6, 2008 at 10:00 AM
BLACKOP555
  • 10,386 POSTS
take and park your vehicle on flat ground and load it down with the normal weight you use in it. then take something 1 inch tall and put it on top of the tire, if it has hardly any clearance don't get it.
i don't suggest 16 inches as that will be a tight squeeze and if you go over too many bumps they may bottom out on you.
Mar 24, 2008 at 8:54 PM
