2003 Chevy Malibu Engine Running Hot after radiator replace
MARIE1236
Engine Cooling problem
2003 Chevy Malibu 6 cyl Automatic
My engine is running hot after my radiator was just replaced. I checked the coolant reservoir and it was almost dry. I never see the fans next to the radiator running? Do you have any idea what could be wrong? Or where I could be losing fluid from, when I cannot find any leaks?
Jan 26, 2009 at 7:17 AM
RHALL77
  • 3,361 POSTS
you need to bleed the air out of the cooling system. there is 2 bleed screws on the top side of the engine.
Jan 26, 2009 at 9:42 AM
