Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Malibu
Engine
Symptoms
Rich
2003 Chevy Malibu dtc 172 code
2003 CHEVROLET MALIBU
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
160DB1999MUSTANG
MEMBER
1 POST
ENGINE HAD A 171 TO LEAN CODE USED FUEL INJ. CLEANER NOW HAS A 172 RICH CODE SHOULD I TRY FUEL INJ. CLEAN OR WHATELSE?
Mar 30, 2010 at 11:37 AM
LEGITIMATE007
Experienced Mechanic
if you have a rich code now after you put injector cleaner in, I would check the fuel pressure regulator, also check the engine coolant temp sensor.
Mar 30, 2010 at 2:41 PM
LEGITIMATE007
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Mar 30, 2010 at 2:42 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
