2003 Chevy Malibu dtc 172 code
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
160DB1999MUSTANG
ENGINE HAD A 171 TO LEAN CODE USED FUEL INJ. CLEANER NOW HAS A 172 RICH CODE SHOULD I TRY FUEL INJ. CLEAN OR WHATELSE?
Mar 30, 2010 at 11:37 AM
LEGITIMATE007
  • 5,121 POSTS
if you have a rich code now after you put injector cleaner in, I would check the fuel pressure regulator, also check the engine coolant temp sensor.
Mar 30, 2010 at 2:41 PM
LEGITIMATE007
  • 5,121 POSTS
