2003 Chevy Malibu check engine light on
TRYNELL
  • 2003 CHEVROLET MALIBU
Engine Performance problem
2003 Chevy Malibu 6 cyl Front Wheel Drive Automatic
Mt engine light is on and I went to a shop and they told me I had two codes. 1)P0303 - which is a misfire detected cylinder in number 3 and 2).P0446 - which is a EVAP. They say I need a tuneup. But how does that fix the misfire. And how do I fix it the misfire if the tuneup dont work.
Thursday, February 4th, 2010 AT 3:03 PM
ERNEST CLARK
  • 1,730 POSTS
How many miles have you gone since your last tune-up? If it's been over 50,000, then I suggest you do a tune-up before trying to diagnose any drivability problems.
As for your misfire, there's several possible causes. (Ignition/fuel) this could be anything from a fouled spark plug to a malfunctioning fuel injector.
Ask the shop for an estimate. If the shop gives you a free estimate and you believe it's a fair price, then it's their responsibility to cure your misfire along with the tune-up. If they perform a tune-up and your misfire persists, then you demand they fix it.
Saturday, February 6th, 2010 AT 7:54 AM
