2003 Chevy Malibu Casting Numbers
2003 CHEVROLET MALIBU
130,000 MILES • 6 CYL • FWD • AUTOMATIC
RANDYROMAN
  • 8 POSTS
I'm getting my heads rebuilt and the shop wants to know what the casting numbers are and if the rockers are 8 or 10mm? how do I find this out? the engine I.D. number tag on the valve cover is gone.
Dec 25, 2009 at 4:44 AM
MIKE H R
  • 3,094 POSTS
Six Cylinder: Passenger side of the block behind the distributor.
The prefix portion of the ID code tells you the assembly plant code, and the engine's production date (for example, 0701 = July 1st....no year is indicated). The suffix portion tells you the original model year / engine / transmission / car combination when it went down the assembly line
Dec 26, 2009 at 2:38 AM
RANDYROMAN
  • 8 POSTS
Well, thats half of the answer. I could just imagine you ranting and raving and just missing the entire reason of the question!!!!
WHERE ARE THE CASTING NUMBERS? and HOW DO YOU KNOW IF IT'S AN 8mm or 10mm ROCKERS?
Or was that not clear?
Dec 26, 2009 at 5:00 AM
RANDYROMAN
  • 8 POSTS
Well, because your answer was so close to not-even-close, I went elsewhere. Thank you for NOTHING!
Dec 28, 2009 at 10:26 PM
