2003 Chevy Malibu
MISSY T
Engine Mechanical problem
2003 Chevy Malibu 6 cyl Front Wheel Drive Automatic
What would the problem be if my engine tries to turn over but it will not? It has fuel presure, coils and cotrol madule is fine.
Aug 30, 2010 at 12:10 PM
  • 75,988 POSTS
Cranks but no start condition-do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 30, 2010 at 12:18 PM
