2003 Chevy Malibu
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOUBLETHEBUBBLES
Changed the battery on vehicle, car would not start. The following morning vehicle did start, was driven to a few places. Returned home, an hour later vehicle would not start. It is trying to turn over, but engine will not start.
Apr 28, 2010 at 1:51 PM
  • 75,988 POSTS
Do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Apr 28, 2010 at 6:11 PM
