i changed my fuelpump and my car still will not start it sounds like it wants to but will not
Apr 23, 2010 at 12:27 PM
BLUELIGHTNIN6
✓Experienced Mechanic
need to check fuel pressure, spark and cylinder compression. let me know results of each. .
Apr 23, 2010 at 5:38 PM
ALEASHA
MEMBER
i looked at all that it is fine what do you think now thank you
Apr 24, 2010 at 3:18 AM
BLUELIGHTNIN6
all of that can't be fine...that's all it takes for the engine to run....
are you sure you tested them correctly? is the engine cranking at all or do you just get a click when turning key?
Apr 24, 2010 at 5:59 AM
ALEASHA
MEMBER
the car wants to start but it just dont stay started, it sounds just like as if you were starting a car thats the sound i get from it we changed the fuelpump and that did not work
Apr 24, 2010 at 6:29 AM
ALEASHA
MEMBER
since that problem ocured the engine light came on and we scanned it and it say evaporative emission system pressure sensor/switch low. could you please tell me what that means, now when i start the car i have to use the gas pedal to help start the car besides it runs well it also has a slight miss in it and a rich smell thank you for your help
Apr 24, 2010 at 4:17 PM
BLUELIGHTNIN6
you wouldn't happen to remember the code number would you? is it p0440?
Apr 24, 2010 at 4:31 PM
ALEASHA
MEMBER
hi the code is p0452 thank you
Apr 24, 2010 at 5:33 PM
BLUELIGHTNIN6
DTC P0452 : Fuel Tank Pressure Sensor Circuit - Low Voltage
most likely cause of this code is a faulty fuel tank pressure sensor, but you will also want to test the wiring to the sensor first. the sensor should be located under the rear of the vehicle, in tank on fuel pump assembly.
