2003 Chevy Malibu
95,200 MILES • 6 CYL • FWD • AUTOMATIC
JWILLI58
Driving and trying to press gas and car begans to lose speed and cut off. I tried to start the car but will not start.
Dec 28, 2009 at 6:17 PM
  • 75,988 POSTS
Do below to determine if it's a spark or fuel problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 28, 2009 at 8:17 PM
