2003 Chevy Malibu
NESSALYNN
Heater problem
2003 Chevy Malibu 6 cyl Wheel Drive Type unknown Automatic 55254 miles
there is something wrong with the heater on my car it will not blow any air out. the defrost wont work. it does not blow any hot orcold air out.
Jan 3, 2008 at 1:28 AM
  • 31,937 POSTS
Hi there,
It is a sad fact that British cars leak! for some reason they always have and they always will. it's only the amount they leak varies. These discoveries are know for this, i have replaced a few manifold and sump gaskets over the years, if you get it done, make sure that they check the top of the "Timing Cover" housing for leaks that is another favorite spot they like to let go. If in doubt about what is required get a second opinion, it's your money so don't be dictated to.
Mark (mhpautos)
Dec 1, 2007 at 10:32 AM
BMRFIXIT
  • 19,053 POSTS
[quote:bd2cff8b61="nessalynn"]Heater problem
there is something wrong with the heater on my car it will not blow any air out. the defrost wont work. it does not blow any hot orcold air out.[/quote:bd2cff8b61]
check fuses and relays
check blower motor
Jan 6, 2008 at 7:56 AM
