2002 Chevy Malibu Multiple Cylinder Misfirings
RDELLISMBA
  • 2002 CHEVROLET MALIBU
Engine Performance problem
2002 Chevy Malibu 4 cyl Front Wheel Drive Automatic
Took my 2002 Chevy Malibu to AutoZone yesterday. Diagnostic test indicated "multiple cylinder misfirings". Any suggestions on how to fix this?
Sunday, August 10th, 2008 AT 4:42 PM
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Sunday, August 10th, 2008 AT 4:53 PM
