2002 Chevy Malibu misses
2002 CHEVROLET MALIBU
134,000 MILES • 6 CYL • FWD • AUTOMATIC
CODYFIELD
  • 5 POSTS
it misses at idel speed but quets when accelerating and at hwy speed. I have put the code reader on it and it says miss fier on cylinder one. I have put new plugs and wiers fuel filter PVC vavel air filter and replaced all intake gaskets and put a new injector in cylinder one. but is stell mising
Oct 31, 2008 at 1:52 PM
DENNYP
  • 1,824 POSTS
Is there corrosion or carbon tracking on the cylinder 1 coil tower?
Oct 31, 2008 at 2:50 PM
CODYFIELD
  • 5 POSTS
[quote:bde01da5ed="dennyp"]Is there corrosion or carbon tracking on the cylinder 1 coil tower?[/quote:bde01da5ed]
no, they are clean and seem to have a good spark it will only miss when in gear
Nov 1, 2008 at 3:54 AM
DENNYP
  • 1,824 POSTS
It sounds like spark jumping to a ground, or a mechanical problem. This would be best to have a shop check it out. It is going to take some time aand specialized equipment to diagnose.
Nov 1, 2008 at 6:31 AM
CODYFIELD
  • 5 POSTS
[quote:cee9c98c21="dennyp"]It sounds like spark jumping to a ground, or a mechanical problem. This would be best to have a shop check it out. It is going to take some time aand specialized equipment to diagnose.[/quote:cee9c98c21]
I fixed it. It was a blown head gasket
Nov 5, 2008 at 9:54 PM
DENNYP
  • 1,824 POSTS
Was it losing coolant?
Nov 6, 2008 at 5:16 AM
CODYFIELD
  • 5 POSTS
[quote:0c822675e9="dennyp"]Was it losing coolant?[/quote:0c822675e9]
Yes, but I thought it was the intake gasket that I had changed befor
Nov 9, 2008 at 2:47 AM
DENNYP
  • 1,824 POSTS
All the little details,no matter how small, will help us to find the best diagnostic route. I'm glad that you were able to find the problem. The spark plugs will normally show the cylinder that has a bad head gasket.
Nov 9, 2008 at 3:04 AM
