2002 Chevy Malibu ingnition lock cylinder replacement
BOBMCGRAW
Electrical problem
2002 Chevy Malibu 4 cyl Front Wheel Drive Automatic 160k miles
i have replaced the ign lock cylinder. the instructions indicate i will need a scan tool to complete the job.
instructions state after replacement the vehicle either would not start or would stall. my vehicle started right up and i have driven it for a week.
the problem i have is the "theft system" lite stays on.
the instructions state, there are 2 versions of a relearn procedure that must be don in order to start car.
a 10 min ver or a 30min ver.
even though my vehicle will start, i have attempted the relearn procedure. however my system fails to turn off the "theft system" lite . it will not do the procedure.
any thoughts ?
thanks
Bob
Aug 30, 2010 at 4:09 AM
WRENCHTECH
  • 20,760 POSTS
You have been told correctly. You will need a Tech2 scan tool to be able to diagnose the fault code.
Aug 30, 2010 at 4:34 AM
