the ignition switch will not turn completely turn off and the miliage light stays on and runs down the battery.
Sep 7, 2010 at 1:01 AM
RANDABRAI
MEMBER
1 POST
i just bought a 01 malibu and on that very same day, i went to start my car after work and it was completely dead. turns out, it had been stuck on accessory the whole time instead of turning off. i had to wiggle around the gear shift and hit it a few times-kid you not!- to get it to shift all of the way into park to turn off. i hope this helps.
Sep 10, 2010 at 12:46 PM
AJBLKNIGHT
MEMBER
I had tried the gear shift multiple times and that does not work. I replaced the key cylinder and the problem is still there?
Sep 10, 2010 at 8:33 PM
