Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Malibu
Engine Cooling
Water Pump
Replace/Remove
2002 Chevy Malibu got a leaky gasket
2002 CHEVROLET MALIBU
93,000 MILES • 6 CYL • FWD • AUTOMATIC
ADAMROC
MEMBER
1 POST
how do i replace water out gasket on waterpump
Feb 11, 2010 at 6:21 PM
HMAC300
Experienced Mechanic
remove the water pump and change the gasket. YOu 'll have to drain the system too. Make sure it's not the intake gasket as they failed quite a bit then too.it will leak right at the corner of the gaskets and look like a water pump gaskket.
Feb 12, 2010 at 3:53 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
