fuel filter replacement
103,000 MILES • 6 CYL • FWD • AUTOMATIC
TRISHALYNN1969
My Malibu will turn over and it sounds like It's trying to get fuel but isn't. I'm thinking, actually hoping, that all I need to do is change the fuel filter because it has been quite a while since it has been changed (at the garage). I have never attempted to change it myself because it doesn't look as easy as it use to be to change them many years ago. I know it is located behind the gas tank. How easy is it to change and how do I accomplish this task?
Apr 6, 2008 at 3:54 PM
DENNYP
  • 1,824 POSTS
Here is a guide to help walk you through the steps and the location of the fuel filter for your car in the diagrams below.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Apr 7, 2008 at 2:47 PM
DAMAN77
Brakes problem
2001 Chevy Malibu 6 cyl Two Wheel Drive Automatic
Ok my brakes have been skeaking alot lately and I am going to change them but I dont know how how easy is it to change them and how do I do it.
also I also need to change my fuel filter where is it located at becuase I need to know if I can replace it myself but if its in the tank no way I can do it
Jan 24, 2019 at 10:12 AM (Merged)
RENAUDTN
  • 636 POSTS
Hi there,
To find your fuel filter, follow the fuel lines starting from the tank; the filter is probably installed in line with the fuel line.
Make sure you relieve the fuel pressure before you remove the filter. Also make sure you install the new filter with the flow arrow pointing toward the engine.
As far as the brakes, i'm thinking you have disc brakes. They're easy to replace: jack up the car, remove the tire, loosen the bolts on the caliper and remove the top one; remove the pads, push the piston back in the caliper with a screw driver or a C clamp , install new pads, put bolt back on there and tighten them, put tire back. Last but not least: press on the brake pedal a few times until the pedal feels 'normal'.
Anyway, i strongly suggest you buy a manual (haynes/chilton). Eventhough both jobs are not difficult, a manual will help you a lot.
NIKITHA
would like to know where the fuel filter is located. its not getting gas
MIKE H R
  • 3,094 POSTS
the fuel filter is behind the seating area under the car and is in line and in front of the fuel tank and is mounted onto the chassis,
MAMAVIVIANP
1998 Chevy Malibu 6 cyl Automatic 185,00 miles
Where is the fuel filter located on this model?
RHALL77
  • 3,361 POSTS
it should be located on the back side of the fuel tank
STAISL
I believe the feul filter is located under the car, on one of the sides. An exact location would allow me to not jack the car up more than once.
My car acted like it rand out of gas, but did not. My first thought is to change the feul filter. The relay to the fuel pump is good, therefore if it isn't the filter, are we talking the feul pump from there. Thanks.
KAITIEDOODLE
I just had the exact same problem with my 2000 malibu and it was the wiring harness to the fuel pump that was bad, the relay switch was fine on mine also. My son works at a local car dealership and one of the mechanics told him malibus are famous for the wiring harness going, it was a simple fix , it is located on top of the gas tank
JAZZIEJAT
Engine Performance problem
2003 Chevy Malibu 6 cyl 89000 miles
where is the fuel filter located
IMPALASS
  • 3,112 POSTS
Hello The fuel filter is located on the cross member just forward of the fuel tank. item 2 on the pic
https://images.2carpros.com/forum/automotive_pictures/248015_1_72.jpg
WINMAN
I changed the filter and now the car wont start.
Is there a fuel safety switch on this model, and where is the relief vavle on the fuel block. Pictures please.
DENNYP
  • 1,824 POSTS
First make sure the fuel filter is installed the proper direction. If so, just cycle the key off to on 4 or 5 times, then try to start the engine.
MOMMYRULZ
I need to know where the fuel filter is on a Chevy Malibu Classic. One guys says in the tank another said in-line just front of the tank behind the heat sheild
BRIAN 1
  • 1,030 POSTS
this one is in-line and behind the gas tank.
MARTINGOLDSMITH
ON the gas tank in front center, I just replaced one. About an hour to take off. Marty
BUCSFAN5
  • 68 POSTS
I'm changing my fuel filter & I'm almost certain I've located it
IM having trouble figuring out how2manuevier my tiny hands to get it out.i was told frm an auto part store tht i wuldnt need tools but a fuel disconnect tool but i think i need more than tht..what's the best & easiest way4me to do this job & to show the boys tht r underestimating me tht i can do it hahahaha
the green and blue connectors have to be unclipped and pushed away from the line to release the line from the filter,
BUCSFAN5
  • 68 POSTS
OK wuld it b red & blue maybe
could bbe
BUCSFAN5
  • 68 POSTS
does the fuel connect tool go onto white plastic cap?
BUCSFAN5
  • 68 POSTS
OK soooo IM getting sumwhere now sweet. me having lil hands I'd be able to do this easy....i cnt seem2 figure out how this fuel disconnect tool works
good luck
LINDEN WILLIE
do i need to do anything special before replacing the fuel filter on my 2002 chevy malibu?
Jan 24, 2019 at 10:14 AM (Merged)
  • 31,937 POSTS
Just be careful in nudoing the fuel line to drop fuel pressure, use safety glasses as fuel may spray out at high pressure till till the line pressure drops.
mark (mhpautos)
ORGANIZER
  • 7 POSTS
how do you change the fuel filter
JDL
  • 16,098 POSTS
Looks like a threaded fitting on one end, use a couple of wrenches, quick connect fitting on the other end. Make sure there is no fuel pressure on the system, before taking any lines loose. The autostore should have a cheap tool for the quick connect fitting. Some of these fittings I have taken loose with a pair of needle-nose pliers. It's best to use the proper tool. The filter I looked at was for vin J.
RHHD76
2000 Chevy Malibu 6 cyl Two Wheel Drive Automatic
where is fuel filter and what tools do i need to replace it
JDL
  • 16,098 POSTS
My info, 3.4L, says it is located under the vehicle rearward of gas tank. Make sure no pressure on the system before taking any lines loose. The filter looks like a threaded fitting on one end, quick connect fitting on the other. The auto store sells tools, don't know the wrench size. They also sell a tool for that quick connect fitting. I have taken those loose with a pair of needle nose pliers, using the proper tool is best.
https://images.2carpros.com/forum/automotive_pictures/170934_malibu_fuel_filter_1.jpg
SAMMY23
1999 Chevy Malibu
how do i change the gas or fuel filter in the malibu?
  • 75,988 POSTS
In-Line Fuel Filter Replacement Removal Procedure The fuel filter is located under the rear of the car, behind the fuel tank. There is no service interval for fuel filter replacement. Replacement is required only if the fuel filter becomes restricted. Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components. Disconnect the negative battery cable. Relieve the fuel system pressure. Refer to Fuel Pressure Relief . Caution: To avoid any vehicle damage, serious personal injury or death when major components are removed from the vehicle and the vehicle is supported by a hoist, support the vehicle with jack stands at the opposite end from which the components are being removed and strap the vehicle to the hoist. Raise the vehicle and suitably support. Caution: In order to Reduce the Risk of Fire and Personal Injury: � If nylon fuel pipes are nicked, scratched or damaged during installation, Do Not attempt to repair the sections of the nylon fuel pipes. Replace them. � When installing new fuel pipes, Do Not hammer directly on the fuel harness body clips as it may damage the nylon pipes resulting in a possible fuel leak. � Always cover nylon vapor pipes with a wet towel before using a torch near them. Also, never expose the vehicle to temperatures higher than 115�C (239�F) for more than one hour, or more than 90�C (194�F) for any extended period. � Before connecting fuel pipe fittings, always apply a few drops of clean engine oil to the male pipe ends. This will ensure proper reconnection and prevent a possible fuel leak. (During normal operation, the O-rings located in the female connector will swell and may prevent proper reconnection if not lubricated.) Using back-up wrench, remove the fuel filter fitting (3). Grasp the fuel filter and the fuel pipe quick-connect fitting. Twist the quick-connect fitting 1/4 turn in each direction to loosen any dirt within fitting. Using compressed air, blow out dirt from quick-connect fittings at end of fuel filter. Remove the quick connect fitting by pushing inward toward the fuel filter and grasping the plastic tab around the connector and pull apart. Remove the fuel filter. Installation Procedure Caution: Always apply a few drops of clean engine oil to the male pipe ends before connecting the fuel pipe fittings in order to reduce the risk of fire and personal injury. This will ensure proper reconnection and prevent a possible fuel leak. During normal operation, the O-rings located in the female connector will swell and may prevent proper reconnection if not lubricated. Remove the protective caps from the new fuel filter. Install the fuel filter (2) in same position as the old fuel filter. Install the fuel filter fitting using a new O-ring. � Apply a few drops of clean engine oil to the male tube end of the filter and of the fuel sender assembly. � Push the quick-connector (1) together to cause the retaining tabs/fingers to snap into place. � Once installed, pull on both ends of each connection to make sure they are secure. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems. � Install the fuel filter fitting (3). Tighten � Use back up wrench to prevent the fuel filter O-ring or fuel pipe from damage. � Tighten the fuel filter fitting to 27 N�m (20 lb ft). Lower the vehicle. Disconnect the negative battery cable. Inspect for fuel leaks through the following steps: 6.1. Turn the ignition switch to the ON position for 2 seconds. 6.2. Turn the ignition switch to the OFF position for 10 seconds. 6.3. Turn the ignition switch to the ON position.
https://images.2carpros.com/forum/automotive_pictures/12900_102900_288310_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_102900_54520_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_102900_54522_1_1.jpg
JDANDERS
I need to replace my fuel filter in the 04 chevrolet malibu maxx. I never have since I bought it with 30,000 miles and now am at 124,000.
Where is the fuel filter located on this vehicle and is it something I can pick up at Checker and do myself?
Jason
Jan 24, 2019 at 10:15 AM (Merged)
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_ff_21.jpg
The fuel filter is located on the cross member just forward of the fuel tank. FUEL FILTER The fuel filter is contained in the fuel sender assembly inside the fuel tank. The paper filter element traps particles in the fuel that may damage the fuel injection system. The filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement.
CANARYBLUE
I have a 2002 Malibu that will turn but won't catch would like to know if I change the screens on the fuel filter will that help or do I have to buy a whole new filter?
SERVICE WRITER
  • 9,123 POSTS
The filter is sealed, so the whole thing needs replacement. Sound like you haven't kept current on the Maintenance? If this is true expect to not only HAVE to do the maintenence now but also fix the problem that was created from the lack of it.
Are you sure it is fuel related?
CANARYBLUE
Hi, thanks for your response. No I'm not sure, but I know it's not the security system because I checked it.
SERVICE WRITER
  • 9,123 POSTS
Shoot some car cleaner or starting fluid into the throttle body, then crank the engine.
