2002 Chevy Malibu
1,000 MILES • 6 CYL • FWD • AUTOMATIC
1COUNTRYGURL
overfilled the oil and it wont turn over have i destryed the motor? can anything be done or do i search for a used motor now?
Apr 1, 2009 at 11:07 PM
2CARPRO JACK
  • 11,533 POSTS
Have you tried draining the oil, installing 5 qts, and removing the spark plugs? If the engine wasnt running then stopped, it may be ok.Use carb cleaner to clean up any plugs that have oil on them.If engine turns, clean and reinstall plugs and see what happens.It will probably smoke for a while, but that may go away
Apr 2, 2009 at 2:21 AM
